EVO X ECU Connector
4820 Vistas
I'm looking for a source for the lever locking 64 and 48 pin ECU connectors used for the OEM Evo X ECU.
They look like the photo below, but I can't seem to identify the brand or model of connector.
The closest thing I have been able to find is the TE MT-2/JPT connectors, however, they don't list the correct pin counts.
I can't personally help but it might be worth flicking an email through to Motorsport Electronics (sales@msel.co.nz) and asking the question. Richard (MSEL) posts on our forums from time to time. I'd also try sales@racespeconline.com (Joel @ Racespec USA), orders@rywire.com (Ryan @ Rywire) and it might be worth asking the guys over at www.milspecwiring.com.
Hi, I know it's been a couple of years.
Did you manage to find the connector? TrialEngineering
Cheers,
Not for the plastic housings. I was able to find a part number and supplier for the terminals.
I ended up recovering the housings and wire seals from a donor harness.
The plastic connector seems impossible to source. Seems like reusing the old connector will be the only way.
Do you remember what brand and series of terminals/pins that connector uses?
Any help is appreciated.
