Ford map and maf sensors
826 Vistas
First, super new to tuning and the likes. Not new to automotive though.
Now what is the purpose of fords map sensor in conjunction with a maf? I'm in the process of building a 2.5 ford duratec from a 2015 fusion. Im using the factory ecm with hptuners. I've added a turbo and moved maf to blow through. I know that these maf don't like blow through but expected map to do something. Watching the data, the maf does nothing. The iat are over 200 degrees F and at about 1300rpm car starts to stumble and go lean, via wideband. And help? Haha..
