Haltech Elite 1500 - Flat Shift config
2912 Vistas
Hello all greeting from Costa Rica,
I'm working on my first build/tune car, my own Impreza GD 02, currently i'm running a EJ205 JDM with 6 speed STI transmission and DBW throttle, i wanted to activate the flat shift function in my Haltech Elite 1500.
I already have the clutch switch line enabled and working, so i set up the the mode to "While Active" the flat shift input enable to "Clutch Switch"
But i'm really lost with all the other configurations, i also want to activate the Throttle blip if possible
Any help will be really appreciated.
Regards.
Daniel,
Before using flat shifting I would verify whether you have shimmed buckets or not. The shims tend to get spit out when the valvetrain is jarred on the EJ205.
If you have shimless buckets, then you're mechanically ready to proceed.
This has the general workflow:
https://www.hpacademy.com/previous-webinars/186-configuring-flat-shifting/
and you'll find some Haltech specific suggestions here:
https://www.hpacademy.com/forum/general-tuning-discussion/show/supra-2jz-closed-loop-flat-shift-cut-tuning-using-haltech-elite-2500/
I also suggest looking over Haltech's support info on those two features because it's very specific and often answers lots of questions.
Here's a link to autoblip:
https://support.haltech.com/portal/en/kb/articles/flat-shift-throttle-blip
Please let us know how it goes!
Thanks.
