Haltech Elite, confused by timing
2709 Vistas
I'll chime in because I had the same problem
It would be pulling timing out due to nearing your revlimiter and i would assume you have the limiter cut set for ignition and soft
To correct this either amend to hard cut or raise rev limiter
