Help sourcing in the UK for heat shrink moulded junction boots
1141 Vistas
Hi All,
Is there a good source for moulded TE/Hallerman Tyton heat shrink boots, the ones I am after are "T" and "Y" shapes in the typical sizes that may be used on an engine and chassis loom
Trying to figure out the naming and identification system they use is also a job in itself, I have found some on RS components and FC Lane, etc but I'm really struggling to figure out exactly where to get them and what ones to get.
Thanks in advance
Get the catalogs from ISMotorsport / Rayfast in the UK. https://www.is-rayfast.com/ The catalog has a page for each type with the part numbers, and dimensions of all the legs (both before and after shrinking).
What you are looking for is called "Molded Transitions", here is their selection:
https://www.is-rayfast.com/catalogsearch/result/?q=molded+transitions
Thanks David, a life saver again
