Hi guysss, i wanted tò share all my work on the Marelli iaw4af
1211 Vistas
Hi guys, I wanted to share my work on my ECU iaw 4af pp hw, because this idea seemed crazy to me tò tune a fiat panda 141, and so I started working on this ECU with the fgtech v54 galletto, the idea of being able to do a launch control pops and bang, since there's nothing around I decided I'LL DO IT, let's get started then if you should work on this line of ECUs i.e. iaw 4af, I discovered several things, starting from the beginning, from the reading, I read it in two ways, the first is in boot mode (which will take out a 328kb file, the complete reading with limmo and it will take max 2 min) or the normal reading 320kb, and it will be without immo, then I did the boot reading, and uploaded it to winols, then take the file and cut it at the end (because then if you go to rewrite it you won't touch the immobilizer, I worked on it all night and during lunch breaks at work, and up to now I have 6 maps, and other maps that I am still defining, and I have a mappack ready, and I also found that if you should block the ECU, you open it I love the epromm st 95160, and from there the ECU is unlocked and you can rewrite it without the epromm, once done you heat it up and it works normally, but you will have to check the immobilizer first, and rewrite it on the epromm before re-solder it, I will share everything on this post, I will share photos and videos of my work, I thank the guys at HPACCADEMY very much for letting me write and share all my work with them too, thank you again from the bottom of my heart, I apologize to everyone for my English but I am Italian and I am only 18 years old,
