Honda COP coil dwell TC-28A
1575 Vistas
Looking for coil charge values, supposedly Honda Accura coils, TC-28A.
TIA
I think this will work:
8v - 5.0
9v - 3.7
10v - 3
11v - 2.5
12v - 2.3
13v - 2.2
14v - 2.0
15v - 1.0
I've also seen tables that have 3.0 ms at 300 RPM, and 2.5 ms from 1000-2000, then 2.0ms from 4000-8000, then 1.5ms 10000rpm+
table is the same for all voltages, but at 8-10V, they use 6.0ms for the 300 RPM.
Thank you David.
