How to run new cars on no linked axle-hub dynamometer?
2769 Vistas
I wanna purchase LAND&SEA dynomite AWD -2000.
But looks like this dynamometer have no synchronization.
Can I running like Porsche, Audi, BMW,VW ect, electronic 4WD cars on axle-hub dynamometer?
I heard new cars can't running on no linked axle-hub,is it true?
Does that mean I can only buy the chassis dynamometer?
I'm very confused.
It really is very dependent on the specific car you're wanting to tune. It's true that many of the modern European cars (even 2WD) will not run properly on an unlinked dyno. I can't give you an extensive list unfortunately of which cars you will have trouble with. If you think that you're going to be running a lot of cars that fall into this category then you'd want to consider something that is linked like a Mustang dyno.
