Injector Characterisation - HP tuners
2137 Vistas
I have a set of Injector I would like to get Characterised for use in HPtuners.
Is there somewhere In Australia that can do this?
Part is Bosch 0280155968
Thanks,
I'm not aware of anyone offering this as a commercial service. If you find someone, please update this thread as I know many others would make use of the service.
I didn't find anyone unfortunately. However a company in the states gave me the data as they sell these injectors. Was nice of them, didn't even charge me for it.
With Hp tuners, inputting the values I got for Short Pulse adder, the values I paste in are changed to values close but not the same.
Eg: I paste in 0.4729, Hp tuners displays 0.4711
Is there some sort of Indexed value system the rounds to the closest values? or something else at play?
EDIT: The issue with the strange values is apparently a resolution issue in the PCM. nothing to worry about.
Thanks,
