Injector data
1945 Vistas
just checking here to see if anyone has any injector data for AUS 925cc injectors part number 10093-925. I have the sheet that came with them but all is listed is the offset. I need injector pulse width vs fuel mass. I know is possible to calculate it but I don't have anything other then the offset so im not 100% sure where to start. I have tried the FIC 1000 data that they had posted hoping it would get me close enough I could tune out the difference in the VE table. Idle AFR was perfect but the car goes full lean with throttle input. Next tried ID 1000 data idle was a little lean and car went full rich when tried to drive also wouldn't accelerate at all due to richness.
