Innovate LM2 Datalogging
2127 Vistas
Hi Guys,
Does anyone have experience using the innovate LM2 to log OBD2 data to file?
I'm trying to do this with the log works software, but I see no where within the software that is allowing me to select multiple OBD2 parameters to log. I do see the list of parameters...but you can only select one!
On the physical device itself though, I am able to select multiple OBD2 parameters, this has me wondering if recording directly to the SD on the device is the only way to log multi OBD2 channels?
Someone please help!
It's been over a decade since I've used one so at the risk of speaking in error or based on outdated information, my recollection is as you described, that you can get what you want by logging to the SD card.
