Is200 timing map
3125 Vistas
Hi all just helping a friend finish his lexus is200 build. It's got a pretty extensive setup on her.
I'm just in process of setting up sensors ect in his emu black to go for a first start.
The issue / help I'm after is there is no base map for the 1gfe that I can find. I'm just asking on here if anyone has experiance with tuning the 2.0l 1gfe motor as to some numbers to set ignition timing to be safe as a start point.
Thanks all
Did you happen to have any luck finding any info?
im currently going through the same thing, additionally its also setting up my first base map - some reasurrance would be amazing
