Knock sensor on smaller surface than 22mm
2220 Vistas
Hi
I want to run my plex in parallel with my ecu knock control got calibration reason.
On my engine I do use the two original knock sensor bungs for the ecu sensors
For plex knock sensor I want to use two other bungs I found on my engine
Unfortunately those do have only a diameter of 15mm.
22mm is required for a knock sensor...
Would the less surface make a big difference? Anyone who tried it and had still good results?
Thanks a lot
I say try it and see. I think it will work fine.
