Link G4+ Evo 8 no start up.
1618 Vistas
Hello mates.
So i have this link g4+ plugin ECU installed with FIC 1100 High Z injectors.
5 bar map sensor wired to ANV1. It will not calibrate and wont start.
When selected 4 bar calibration from the list, it did calibrate but still didnt start.
PCL attached for reference
  • N1.pclr
set it up using one of linear Cal tables. for example
0kpa = 0.5v
500kpa = 4.5v
not sure which sensor you're using exactly but some documentation would be helpful.
The map sensor has been calibrated now to Link internal 4 bar sensor but still no start.
Can anyone check on the bench if all is good and it fires up ? or this is related to tune?
I have been helping RH9 on the Link forum, so not ignoring this post, will just continue to work over there.
