Link Monsoon g4x +B16 starting issues
2280 Vistas
Hi all
Im having issues with getting this b16 started.
Car is an ek civic rally car
Jenvey throttle bodies
Crank signal only . 36-1 Reluctor
Wasted spark with c20xe coil and bosch ignitor
Multipoint group injection
Was previously running an Omex ecu, now swapped with a Link monsoon g4x
Equation Load source =bap (no map sensor )
Fuel and ignition tables are TPS/RPM.
Files attached hopefully someone will find an error in it .
Thanks
EDIT I couldn't upload the files,i tried to as zip folder too .
I should have added.
The coil and injectors aren't firing when I crank the starter but I can fire them in test mode
The crank sensor is wired with reverse polarity, swap the +/- pins in the crank sensor plug and it should be happy.
Hi Adam. I'll swap them and report back.
Thanks
Hi Adam
That worked a treat , car is now running.
What is the tell tale sign in the waveform that tells you that the polarity is reversed ?
Thanks
The missing tooth is inversed
