LM2 Wideband - HpTuners - Not connecting
1834 Vistas
Hi Everyone,
I am needing some help.
I understand this topic has been talked around the threads for quite someone, unfortunately the information relating this this and the webinars are not working for me!!
I am having trouble connecting the LM2 wideband to Hptuners, I connected it via the D9 cable through a serial port and even used the LM Programmer as per Andre's advise on the webinar with no luck unfortunately.
Its obvious that this system is a headache. Is there any other possible way for tuning AFR and VE tables with this device with AFR/EQ error's through road tuning? or another effective way of getting AFR maps/tables correct with using a wideband but not having it in the scanner?
