Dear All,
i recently acquired a speediuon ecu for my blacktop 20v 4age engine with a distributor. i am using the engine for racing. The ecu is without a wiring harness. i am requesting the platform members to help me with the connections from the ecu the different sensors, and any other guidance for optimum performance
Regards
Hajj
I would start with the Speeduino manual found here:
Dear David,
Thank you for your quick response. I appreciate you sharing the link, which contains all the information I need.
However, due to time constraints, I was hoping you could kindly assist me with the essential wiring connections rather than having to go through all the documentation at this stage.
I have a rally event coming up next weekend, from 30 October to 1 November 2026, and I would really like to get the Speeduino ECU installed and mapped in time to improve my car’s performance. With the event preparations and other commitments, going through all the documentation, completing the wiring, and mapping the ECU within a week may be quite challenging.
Specifically, I would appreciate your guidance on connecting the Speeduino board to the distributor, Toyota ignitor, ignition coil, TPS, injectors, and other essential engine sensors and components.
My car is a Toyota Corolla AE101 fitted with a 4A-GE 20V Blacktop engine. Fortunately, I already have TunerStudio installed on my laptop, so I am ready to proceed with the configuration once the wiring is sorted.
I would be extremely grateful for any practical assistance or guidance you can offer to help me get the car running safely and reliably before the rally.
Thank you once again for your time and support.
Best regards,
Hajj Ahmed
