Hi all,
I'm working through a warm-up issue on my NB 1.8 VVT MX-5 (Project Nemesis). It has an Eaton M45, an intercooler, a Motorsport Electronics ME442 and a pre-cat wideband connected to the ECU's onboard controller. It runs well once warm. During warm-up I can get an uneven idle around 39–43°C and an occasional hesitation when first opening the throttle. The return to idle after a blip can also feel abrupt.
Both attached runs were stationary and started at about 7°C coolant. I let it idle, then used brief throttle inputs and some holds around 2,000–2,500 rpm during warm-up.
• 7 November — DigiTune V10. At roughly 150–175 s (39–43°C), the lambda fuel multiplier was about 0.86–0.92 while the logged AE addition was zero. The onboard wideband reads around the target for much of that window, although it moves about.
• 11 November — QDV10-02, with lambda feedback inhibited below 60°C coolant. Idle and throttle response felt smoother on that run. The lambda multiplier stayed at 1.00 through the same coolant window. Around 195.5 s (47°C), one throttle opening logged +23.92 on the AE VE-added channel. At that sample the onboard AFR was 14.88 against a 14.03 target. I'd like to understand the sequence around the event, allowing for the wideband response delay.
The logs contain two AFR traces. The external AFR channel reads much lower than the onboard wideband in both runs. In these captures, Lambda Curr AFR 1 follows the onboard reading, so that's the trace I'm using for this comparison.
The two runs also have different base VE tables. I've prepared a follow-up using the same base VE as the 7 November run to isolate the 60°C feedback threshold. The current pair is useful for spotting patterns, but I can't attribute the improvement to the lockout alone.
For anyone familiar with MEITE, what channels or status changes would you look at first to tell whether the idle hunt starts with fuelling, idle valve duty or idle spark correction? On a throttle blip, how would you distinguish genuine acceleration enrichment (AE) from an idle control transition at tip-in, and from fuel restoration or idle catch on the way back down? I'm particularly interested in a way to read the traces before deciding which table to touch.
I found Vince's Mk1 ME442 thread useful for distinguishing the initial throttle opening from the dip after lifting. His recording starts above the coolant window I'm investigating here:
I've attached two CSVs with elapsed time, coolant temperature, RPM, TPS, MAP, AFR target and readings, fuel trims, AE, idle duty/status, ignition and overrun. Start at about 150 s in the V10 baseline and 156 s in the lockout run. Any pointers on what to look at next would be appreciated.
Alan
