Motec M800 connecting to laptop
3682 Vistas
I've got a 2007 wrx sti in for a gearbox swap to sequential , i would like to setup the shiftcut but the car has a motec and i dont have that cable.
It seems like someone before has hacked into the wiring of the connector to the can wires for some reason. Could it be possible to connect to the ecu with just wiring something into the can ?
i've got a ecumaster ecu-to-can if that helps
You need a MoTeC UTC to communicate with the M800, there's no way around it.
allright thanks for confirming that
