[MOTEC M800] Need help with CEL activation when ALS/ORB is switched on
2457 Vistas
Hi,
i need some help with the CEL activation on a Motec M800 Subaru STi Plugin. A Customer wants to have the CEL blinking when ORB/ALS Table 1 is selected and a permanent CEL when Table2 is active. I already configured the ORB Select Switch but i cant remember how to map the CEL properly. The ECU manager doesnt allow me to use ORB Select as a Axis on the Engine Warning Table.
Thanks in advance
