Mx5 on ecumaster black
1578 Vistas
I recently have upgraded my ecu to an ecumaster black.
my engine specs are
bp4w engine fully built bottom end
head has oversize valves and dual springs and titanium retainers and turbo cams.
efr6258 on an equal manifold
skunk2 intake manifold with skunk tb
the problem im having is one the trigger signal in the log is really dirty and having to be filtered alot….. the scope looks clean
and also im getting a missfire from idle to 3200 which i have tried multiple things including change the main cable to the csp aswell.
Hi Ashley, are you using a good shielded cable for the trigger wiring. I have found the classic had some noise if using the flying lead kit and missfires.
