Nissan Maxima v6 model 2002
3214 Vistas
Hello
please i wanna ask any one try to start Nissan maxima 2002 with motec ?
the car as i search it have only crank sensor I didn’t find cam sensor on it
so how to setup the trigger?
and what is the right firing order
the ecu is motec m84
Do you have the factory workshop manual? You will find the necessary information about firing order, wiring diagrams and pinouts for various sensors.
Hello david
i try to find it in google but nothing
no information online
i find the cam sensor on the side of the engine and i share it with motec it sync now have spark
but the fireorder i put 123456 as google say but its look like wrong
Its not started at all the way
i put the ign and inj fireorder as 1-2-3-4-5-6
its spark on plug and fuel pulse came but not start
i think the fire order is wrong
The VQ30 firing order is definitely 123456. What ref/sync mode are you using? Im not even sure if the M84 supports the VQ30 pattern. It has 4+1 for the ref and a weird 21 tooth pattern for the sync.
You would be better off with a "standard" trigger pattern. I am going 60-2 with a single cam wheel trigger on my VQ30 with Motec 130.
I HAVE NO ISSUES I WILL SWITCH TO M130
BUT WHAT I SHOULD SET THE REFF SYNC TO ??? CAN YOU ADVICE ME PLEASE
CAN I DO IT BY M130 ??? I NEED TO START THE CAR AT THE FACTORY SENSORS AND TEETHS
