Hello, i have a bmw e36 driftcar- s50 turbo. Use G4+ STORM.
It is extremly noicy when it hit the rev limiter. Big bangs…. To much..What can be done to make it less noicy?Thanks.
You should watch this webinar -- it is specifically about how to make a smooth rev-limiter with the Link G4+:
https://www.hpacademy.com/previous-webinars/084-link-g4-rev-limit-configuration/
Since it's boosted, you might also want to reduce the boost as you approach the rev-limit. Get it to run out of power to stop the engine from accelerating.
Håvard,
The link David provided is for your system so that will be a big help and likely resolve your concern.
A broad RPM limit control range with low initial cut % will soften things up significantly.
Thanks guys :)
