Portable Wideband
1359 Vistas
I'm looking for a portable wideband to use with a tailpipe clamp.
Can I use an Innovate MTX-L Plus wideband and get an acceptable accuracy as the LM-2 portable wideband?
The MTX-L is cheaper than the LM-2. If the reading is accurate using a titepipe clamp, I would rather the MTX-L. Also I don't want to permanently install it because I'm still learning and may I change my car.
What would you use with a titepipe clamp?
A tailpipe clamp is only useful if you are only going to be testing a car for a few hours. Any longer than that, and it's really easy to have a bung welded into the exhaust. If you need to remove the Lambda sensor, you just install a plug into the bung.
You're going to get the same accuracy with either of the Innovate products. But I believe the LM unit is capable of logging the data so it's more capable.
Hi David. Thanks
So would I need to wait a while after a few hours of use before to continue testing the car if I use a tailpipe clamp?
Well I thought about the bung welded but what about if I need to use the wideband in other car
