rough cold start due to flap delete
2101 Vistas
hello all car golf 5 gti with upgraded turbo and flap delete kit the issue occurred in the rough cold start along with misfire too any suggestion to solve this issue
brgrds
raed
Why don't you put the flaps back in? Is there a reason you removed them?
You may have an air leak, which isn't uncommon, with it cold started, spray some brake clean or engine start around the areas you unbolted while fitting the kit.
You may also have missed hooking up a hose, or connected a couple round the wrong way, or missed recommencting a sensor, or whatever, when reassembling everything.
what gord said.
Also, post your current file please and a log.
