Seasonal Temp Variance
1579 Vistas
Hi Guys,
I am facing the below issue in every summer might be the Atmosphere temperature, appreciate your expertise knowledge.
During the winter Atmosphere temperature is 20-25 C whereas an engine IAT is 32-35 C, with good performance.
And when summer comes, it will change to IAT 45-53 C, whereas atmosphere temperature would be 38-45 C. AFR is getting lean, and there is a sound from engine detonation. Eventually engine turns to poor performance. I have retarted 4 degrees in each cells in that area, but still the same.
Why its having seasonal changes.? What would be the issue.?
Please see the attached Log file
Thanks
  • Over-temp-log.llg
  • Over-temp.pclr
What are you tuning with? It sounds like your controller isn't compensating for changes in temperature.
Hi philip, thanks for the feedback, I am tuning with Link mosoon with pump gas 98oct, Hodnad K20 motor
Is it using a hot wire type air meter?
