Some Data log Channels are not showing values in VCM scanner
8329 Vistas
Hi all,
i have recorded a data log this morning, i have found that a few importatant data channels are not recording or even showing a value when viewing live. For example a few of the channels not showing a value are: commanded turbo vane position A and B, Fuel injection timing (which probably the most important), Injector PW (there is no channel to select for this data) Is this a setting that i have missed or is it possible the ram doesn't support some of these channels?
Hi Joe,
Sometimes you will find it might be under another name. Example the injection timing might be under "main inj timing" and Injector pw might need to use something like "Cylinder 1 Injector PW"
Failing that, (assuming you have the latest version) if you can not find the correct parameter it might be that the PID is not available in the scanner. I would need contact HP Tuners and ask them if this is the case and if the PID will be added.
