Starting to tune my 6L LS LY6 variable valve timing engine swapped into my E53 BMW X5... and need some help disabling 02s sensors and Evap sensor
2032 Vistas
Hi, I'm new to tuning and LS swaps in general but the engine is in and I just installed a stand alone wiring harness from Wiring Specialties. The next step will be installing my wide band sensor and then begin tuning. I deleted the CATS but kept the post-CAT 02 sensors. I also deleted the A/C and want to disable it along with the pre-CAT 02 sensors and the evap sensor but I'm not sure where to look. Hopefully someone on this forum can help me out with this.
Thanks guys
