Tuning a 2018 gt350 with pro charger
1656 Vistas
Any input here would be helpful... tuning a 2018 gt350 with pro charger using SCT.. the left camshaft is not responding the way the right one is. but there is no way to adjust them individually. no prior issues to vehicle so rule that out. I know there was subtle changes to the PCM in 18' but shouldn't be anything excessive that would cause this. has anyone had any of the same issues or doesn't anyone know why maybe the left isn't responding the same. thanks for any help.
That sounds like a hardware issue from what you're explaining? There are a bunch of issues that can create this (we've just been through the same in our Subaru STi), particularly due to oil contamination although this would hopefully be unlikely on such a new vehicle. Do you have any codes present?
No codes Andre.. vehicle had 66 miles on it straight from dealership to shop for install.. I drove the vehicle around for about 20 miles previous to install and it drove completely normal no issues. I think that's why its so boggling lol. I appreciate the input though hopefully Sct can provide an answer to what's going on.
