Tunning a stock ECU
2061 Vistas
Hello all.
I am new on the ECU tunning.
I previously had an Emerald K6 on a zetec 2.0L naturally aspirated that I played with a bit.
My question is, how can you tune a stock ECU on a car? Is it possible? and what is the hardware and software that is needed? Even if the above are available, is it possible to access the software and edit it? How?
Is there a series of videos or even a single one specifically on this topic on the HP Academy website?
Thanks in advance
