Hi all, I needing some help on setting up CAN on a haltech elite 2500 to a turbolamik tcu on the ZF8HP70 transmission
Hey Eddy, what's your specific question? Have you been through the CAN Communications course? If not I would start with that to cover all the basics (and a bit more) - https://www.hpacademy.com/courses/canbus-communications-decoded/
I'd also make sure that it is a transmission Haltech supports in regards to it being something that is relatively straightforward 'plug and play/setup' or something that is going to be a fair amount of work.
