Voltage regulation for fuel system mapping
1907 Vistas
Hi Guys,
I had an idea and i need some feedback.
I am trying to figure out a way of improving my Injectors dead times and fuel pressure mapping over voltage. The project is 1.3lt NA club level rally car on Elite 1500. (injectors are 140cc , or alternatively 250cc or 400cc as upgrades).
I come up with the idea of an external PWM controller controlling the pump power and the injector power in 2 separate steps. This way i could adjust the voltage seen by the respective components, without changing anything else.
Is there any sense in this idea?
Will the PWModulation affect the injector pulses?
Will a normal pump survive some time of PWM control?
Thanks...
Hello
pwm to an injector power is not ideal at all. i am saying this with no real data of proving it will not work. i really think it wont work though BUT
i say give it a go and find out and share your findings
thinking out side the box is good way to learn
Regards Ross
