With what reflash tuning brand should i start tuning?
2008 Vistas
Hi everyone,i am a novice tuner (in theory) and i want to start tuning with reflashing method on a factory ecu.What brand should i buy so to be easy and low cost for reflashing an ecu?I am considering to start with my hyundai i20 1.2 2009 N/A model if it is necessery for you to know.
Unfortunately there isn't a simple answer for you. There are really no universal reflash packages that will cover every car on the planet and most professional tuners will have 2-3 software packages they use depending on the brand of vehicle they're tuning. You'll often find that even when there are a couple of options for a particular car that one is more complete or user friendly than the other. So really the question to ask first is 'what cars do you plan to tune', and then you can narrow your search down to software that will support these brands. Unfortunately I can't make any suggestions regarding hyundai as it's not a manufacturer I've personally reflashed.
