WMI Setup
1653 Vistas
I had a short which blew a 20A fuse to the WMI Pump. The pump is PWM'd. The problem I now have is the WMI SS Relay will not activate.
I have checked the Pump will go, checked the 5A fuse between the ECU and the WMI SS Relay - OK.
I suspect the SS Relay is damaged but before I replace it can some have look/check my ECU setup will work just incase I have accidently altered something.
ECU Setup attached.
