Double wish vs multi link
Fundamentos de la alineación de ruedas en el automovilismo
Debate y preguntas relacionadas con el curso Fundamentos de la alineación de ruedas en el automovilismo.
1715 Vistas
Can someone please confirm what the type of suspension setup is present on the rear axle of an Evo cp9a.
I would describe it as a multi-link.
Normally, for a double wishbone, at the hub there is a single top pivot point, a single bottom pivot point and a toe link. Three main points, in total.
From the exploded suspension illustrations, see link below, there are two lower mounting points making a total of four on the hub.
https://www.google.com/imgres?imgurl=http%3A%2F%2Fwww.viamoto.co.uk%2Fprodimages%2Fevo-7-8-9-rear-droplink-location-exploded-diagram.jpg&imgrefurl=https%3A%2F%2Fwww.viamoto.co.uk%2Fproducts.php%3Fcat%3DEVO%2B7%2B8%2BCT9A%2B-%2BSuspension%2B-%2BMisc&docid=GV8GmZgHUqLUYM&tbnid=QGb-C2whMnzhMM%3A&vet=10ahUKEwj28Mrlj6bnAhVd4XMBHW5RC0EQMwhZKAUwBQ..i&w=1000&h=653&client=firefox-b-d&bih=1295&biw=2400&q=Evo%20cp9a%20rear%20suspension%2F&ved=0ahUKEwj28Mrlj6bnAhVd4XMBHW5RC0EQMwhZKAUwBQ&iact=mrc&uact=8
