YESTERDAYS HP TUNER GM LESSON
Preguntas del seminario web
1728 Vistas
How can I setup my data logger to display the values or pids to match the one used in the video. I wanna reference the video to my data because it was very well setup and understood. that alone was the first reason I joined HP Academy. thanks in advance
If you want to add a PID to the channel list then you can do that by right clicking and selecting 'Add Channel'. The 'Insert' key and the little 'Gear +' icon in the tool bar will do the same thing. You can then add a PID to the chart logger by right clicking on the chart and selecting 'Charts Layout'. You can then add a channel to an existing group, add a new group, or move channels or groups around to suit. The Worked examples in the course also cover the basics of this.
I'd suggest popping into the webinar archive and use 'HP Tuners' as the search term. You'll find plenty of webinars that cover a wide range of scanner setup info which will help you out. Here's a couple:
https://www.hpacademy.com/previous-webinars/219-getting-wideband-afr-data-into-vcm-scanner/
https://www.hpacademy.com/previous-webinars/215-how-to-use-histograms-in-hp-tuners/
https://www.hpacademy.com/previous-webinars/199-optimising-your-tune-using-short-and-long-term-fuel-trims-stft-ltft/
Great thanks man
I Own an LM2 I have the both the programmer and Logger for the LM2 software. I also have the serial adapter cable as well as the Usb.
I added the channel
serial Port- Innovate SP AFR- and innovate SP Status but it wont read anything unless I got to transform
