difference between tuning a turbo or N/A car
Ajuste de carretera
7033 Vistas
Hi, in this course you explaned the hole video based on a N/A car, so i was wondering if you or how you should do when tuning a turbo car? is there any difference between tuning a N/A car or a turbo car? do you ad more fuel on a specific point or how do you logg the runs correctly ?
should i do more full throttle runs or how does it work ?
thanks !
Im wondering about this too. Anymore insight would be awesome.
Except the specific settings for a turbo application (like boost control) and the scale of the map sensor; it's basically the same thing.
you should watch that webinar:
https://www.hpacademy.com/previous-webinars/turbo-tuning-motec-m1/
It's a question we get a lot, but in reality there is no real difference. The techniques we use and the approach we use is the same as for a N/A engine. It's just the aim mixture and ignition timing may be a little different.
