IAT and CTS haltech
Ajuste de carretera
4050 Vistas
hi
I am using haltech elite 750 on my lexus is250 2jz swap. My problem is that Both air temp and coolant temp always read error codes. They don’t accept any calibrations. Also I tried to erase them, but they did’t. Homever, fuel pressure sensor, on-board map sensor and wb1 all are calibrated, but they didn’t show any reading !!! What is the problem exactly ?
If the IAT and ECT are constantly in error I'd be suspicious that you may have a wiring issue. What is the specific error code you're seeing? Make sure that you've got one side of the sensor wired to a sensor 0V at the ECU header plug and the other side should go to pin 29 (IAT) and pin 30 (ECT).
Have you added a gauge to your tuning page to show your fuel pressure and wideband (MAP should already be displayed).
Codes are P0116 and P0117. I have solved the problem. Sorry, the problem was that I forgot to put the pull-up to enable mode. Another question is : Can we depend on this video for choosing 515 angle as a reference tdc angle for all JZ vvti engines without timing light test ? We suppose here that our timing belt installation is correct. (direct fire ignition and sequential injection are used)
https://youtu.be/2yoxiKJ1KzY
