CAN Output to PMU
9 Vistas
So I'm running a link G4+ Xtreme, from around 2014. I have CAN enabled and will have the CANBUS output fitted as in the right of the photo.
Since its an older ECU, I am not sure how functional the CAN systems are? My fan is currently setup on Aux 2 output, but I was hoping to change all my ECU outputs to CAN, to limit the amount of input wires required for the PMU and have less wires running under the dash.
Will it be easy for me to setup the fan output over CANBUS? Same goes for fuel pump on signal. Only data I really need is an on signal, I still plan to use the ECU to control when they turn on rather than the PMU.
If needed I am running two CAN switchboards, I still have a couple of digital inputs spare on one. So I can wire AUX 2 to this if I fail with the CAN. But the plan was, CAN comes from the Link, then SB behind Console, then SB behind Dash, then into the PMU.
