Base ignition
Ajuste práctico independiente
2066 Vistas
Hi,
where will I find the base ignition tables for na and turbo/supercharged for road tuning
Thanks
Hello Neville
Base ignition tables will normally in base maps supplied by ECU suppliers if it is a plug in ecu, a factory ecu already has base maps to start with in the ecu and aftermarket wire in ecus normally have a good forum user that may share there base ignition map. ideally we would hope after our webinars you will be able to make your own
Regards Ross
