Display one decimal place of the value in Fuel VE Table
Ajuste práctico independiente
Módulo correspondiente: Ejemplos resueltos > MegaSquirt MS3Pro > Paso 7: Ajuste del combustible en estado estable
2357 Vistas
The Fuel VE Table of TunerStudio that I am using does not display numbers up to one decimal place.
TunerStudio's Fuel VE Table used in the webinar is displayed to one decimal place.
How can I display the values in the Fuel VE Table to one decimal place?
-- Google Translation --
What version of Tuner Studio are you using? What project did you start from? I have 3.1 installed, (using the Sample Project), and my Fuel VE Table1 as one digit to the right of the decimal point
I have checked manual for 3.0.7 version and there are no any digits after decimal point...
David,
Thanks for the reply!
The version of the TunerStudio I use is TunerStudio MS Ultra 3.1.08.
Connected to MS2 EXTRA 3.4.4 Release 20201006.
Set InCrement Amount can be set to 0.1.
When you press /., It is increasing by 0.1.
When you press /, presses 0.1.
The current Fuel Ve Table value has a decimal point.
Executive value 30 → 30.5
Press /. Press 5 times to 31.
The display of the Fuel Ve Table value is 30, but the actual data is 30.5.
georg1970,
TunerStudio's Fuel Ve Table, which was used in Webinar, was displayed up to a single decimal point.
I posted a question to the forum, wondering if the tunerStudio I was using would also be displayed up to one digit.
I guessed that MSPNP2, which I am using, cannot display one decimal point.
Therefore, I give up on displaying one decimal point.
Thank you everyone.
