Dynojet inquiry
Ajuste práctico independiente
4045 Vistas
Hello everyone,
Can i tune on a steady state ( same rpm different loads ) using a eddy current dynojet?
If the dynojet has an eddy current power absorber then I'd imagine you should be able to. The only dynojet dynos I've used have all been inertia type so I haven't experienced their load bearing dynos.
Yes you can do steady state using the eddy current units, the rpm signal must come from inductive pickup or gear ratio. It work pretty good to tune afr maps , wgdc and others.
Regards
