ECU master - Analog input setup
Ajuste práctico independiente
2906 Vistas
Hi everyone,
I am new to the ecumaster platform and I am currently about to finalize my build to do the first start up. Car is a Genesis with a 1JZ n-vvti.
I do have a radium fuel cell and also got their fuel level sensor. I did some calculations and for it to work I did have to get a 100ohm pull up resistor which gives me a nice graph slope. I did configure the sensor to be an analog input in my ecumaster classic.
In the sensor menu I can put some extra sensor and the fuel level is an available option. I did install it on my AIN#3.
When you select the analog inputs menu, you can enter your sensor ratio and offset which I do have as I did my calculations. The problem I see is that you can also have access to the fuel level sensor calibration graph. This graph does not changes when I do add my ratio and offset in the analog input menu.
Question is which one have priority in the system, the sensor calibration or the analog input menu?
Thanks
