Ecu master black 2jz ectsi dbw
Ajuste práctico independiente
5888 Vistas
Need a bit of help, made a wiring loom for a 2jz e46 emu black ecu using the oem toyota etcsi throttlebody.
Cant get it to work correctly, ive used the emu black 2jz throttle preset and then when i do dbw calibration it gives me an error.
But when i do a output test on hbridge B it opens and hbridge A nothing happens. All sensor inputs for throttle body work and are set in dbw parameters.
Any ideas?
some extra info, in the emu software theres a pinout for the toyota TB plugs. when i use that pinout my signal is from high to low voltage when i open throttle and an2 goes to 0 volts.
when i use the pinout from the link g4x software which is different i get the same signal but from low to high voltage when i open throttle but an2 goes to 5v instead of max 4,5v.
I have same problem, do you have find solution ?
Has ECUMaster support or your ECUMaster dealer been able to suggest a solution?
I wish I could offer a direct answer, but it's not a combo I've used.
Usually when fitting an aftermarket to that throttle most people delete the electronics and just run the cable as a direct drive
https://www.driftmotion.com/2JZ-GTE-VVTi-ETCSi-Drive-By-Wire-Delete-p/dm3403.htm
This is the kit I've used in the past
Hi Kenny7
Did You get it done with stock 2jz TB and emu black??
I got gte vvti and I would love to switch from that stepper motor (as temporary solution)to dbw like it's stock controlled.
