Ecu master classic
Ajuste práctico independiente
5377 Vistas
Hello .... how do I setup the aem xtype wideband in the ecu masterclassic
You would need to connect it this way :
Wideband -------> ECU
White Wire ----> Analog Input (you can choose the one you want)
Brown Wire ----> Sensor Ground
Then, in the sensor tab, oxygen sensor parameter, you select external controler, and select the fuel type. You select the analog input you connected your wideband to in the list. Finally you need to sent the calibration "AFR at 0V" and "AFR at 5V" according to the scaling formula at the page 13 of the manual. I always confirm the scaling that my wideband gauge reads the same as what I see in the ECU Master Software.
Link to manual : https://www.aemelectronics.com/files/instructions/30-0334-X-Series-OBDII-Wideband-UEGO-Controller-Gauge.pdf
