[EMU BLACK]Regarding the warning if the basemap is created with old firmware
Ajuste práctico independiente
4803 Vistas
I downloaded the basemap from “ECUMaster USA”.
When I open “JZA80 2JZ-GE 330cc Distributor Startup EMU Black_rev1_2.emub” with “Emumaster Engine Management Unit BLACK Client”, the following warning appears.
Loading project warning log.
Loaded project was created using firmware version 2.122
If your firmware version is lower than loaded project version we strongly recommend to upgrade your firmware.
Warning: Cannot find symbol gapDetectionScaleRunning in current project. Skipped.
Warning: Cannot find symbol gearCutCANID in current project. Skipped.
Warning: Cannot find symbol gearCutCANIDByteIdx in current project. Skipped.
Warning: Cannot find symbol gearCANID in current project. Skipped.
Warning: Cannot find symbol gearCANIDByteIdx in current project. Skipped.
Warning: Cannot find symbol dsgThrottleBlip in current project. Skipped.
Warning: Cannot find symbol dsgThrottleBlipMaxDuration in current project. Skipped.
Warning: Cannot find symbol sendEcumasterDataToRC in current project. Skipped.
Error: Cannot find table tpsMapFuelCorr in current project. Skipped.
Error: Cannot find table tpsMapIgnCorrection in current project. Skipped.
Is there a reason you can't use the latest version of the ECU Master EMU Black client? I would do that and update the firmware in your EMU Black as suggested by the messages.
We're up to Client version 2.16x now, those parameters just didn't exist when the map was created. It gives you a warning because it has no parameter info in the map for the listed items.
Ignore them and go through the map anyway and update anything relevant to your car.
Here's the comparison.
The left is the original file.
The right is the file opened and saved by "BLACK Client.
The number of items has increased from the original.
The values of eTqMapBins8 and eTqRpmBins8 at the bottom have changed,
custom*****8, dsg*****, and idleDSG***** have increased and have values in them.
Is this a problem?
