Fuel MAP tuning
Ajuste práctico independiente
2277 Vistas
In all the examples explained can you confirm whether tuning was performed in EGO closed loop or EGO open loop. Which is better?
in all the worked examples we have closed loop fuel control disabled. You can choose to tune either way however if you leave closed loop enabled then you need to account for the closed loop trim being applied as this indicates how far off your map is.
Thanks Andre.
