Hi, I'm having problems with the crankshaft position sensor. Fueltech ft450 k24z7
Ajuste práctico independiente
2895 Vistas
I'm using the original k24z7 tone wheel which is 60-2
Perhaps this video will help you.
https://www.youtube.com/watch?v=0gBYPvyVbkE
You say tone wheel, but I think the sensor is a hall effect on the OEM application. Can you connect an oscilloscope to confirm the crank signal looks good?
i could send you the settings for the k24z7 engine
