Imjectors for a 50/50 nitromethane mix
Ajuste práctico independiente
4744 Vistas
Hi do you know something that is nitromethane compatible? I'm looking for 2000cc injector that can withstand nitro mix of 50/50 in a High impedance injector. Thanks in advance.
Assuming you're familiar with the fuel blend, and just how dangerous and problematic it can be, I'd suggest enquiring directly to the major injector manufacturers. If required, I would expect them to be able to custom make injectors for your specific application.
Frank you can use siemens Deka 2300cc they withstand any fuel
Thanks
