Injector settings
Ajuste práctico independiente
3394 Vistas
Hi how do you input the injectors info on the platinum pro
The platinum pro from Haltech has a relatively simplistic injector model and all you need to enter is the injector dead time values. You can find this under the Fuel - Inj Dead Time option. If this isn't visible then you need to select the dead time tick box in the Fuel Corrections options in the Main Setup - Advanced - Main tab.
